942 install question
  • WELCOME TO THE NEW SERVER!
sbturner
173
Georgia
Ok, getting my 942 installed on the 13th and when added to my new HDTV I will HD finally! I am replacing my 721 and a 301 on another TV. I have a 522 controlling two other tvs. My question is on the second tv on the 522 it is broadcast on channel 73. Is there a way to diplex both the 522 and 942 signals into both second tvs if say you broadcast the 942 signal on say channel 99? Can this be done so both second tvs can access both DVRs? Also should I buy a HDMI cable or is the supplied HDMI DVI cable good?
Yes on the signal combination.
The HDMi to DVI cable is fine, but if you're saying that your TV has HDMI and not DVI, then yes you'll have to buy an HDMI cable, but only if you want the audio on your TV, otherwise no big deal.
sbtuner,
I see that you're in Georgia. How many dishes(in which orbital slots) and cables are you going to need to get all programming(including the Voom 10 from 61.5) off of Dish?
