SOLD!! AC Infinity Aircom T10 Audio Component Cooling Fan, Programmable, 17", Front Exhaust, Like New
FTA4PA
Satellite Guys Family
9,150
8,459
Central Pennsylvania
I am selling my AC Infinity Aircom T10 audio component cooling system. This was only used for about a week with an older amp before it was taken out of service upon buying a new receiver. As such it is in nearly new condition. It is designed to set on top of your receiver or other audio component and the three programmable fans pull heat from your component and exhaust it away to extend component life.
These units currently sell new for $129. Asking $69 + shipping. Here is the description and operating details from the AC Infinity site:
  • A quiet fan system designed for cooling receivers, amplifiers, DVRs, and other AV components.
  • Protects components from overheating, performance issues, and shortened lifespans.
  • LCD thermostat programming with six speed controls, alarm alerts, failure triggers and memory.
  • Contains three dual-ball bearing fans with PWM-controlled motors to minimize noise.
  • Dimensions: 17 x 13.5 x 1.5 in. | Exhaust: Front | Airflow: 160 CFM | Noise: 24 dBA | Bearings: Dual Ball
Product Description
A quiet cooling fan system designed to be placed on top of AV components such as receivers, amplifiers, and DVRs. Maintaining an optimal temperature for components prevents overheating, ensures constant performance, and extends their lifespan. The LCD digital controller on the front of the system features a smart thermostat with speed control and status alerts. The steel enclosure houses three dual-ball bearing blowers that pull heat out of the component and exhaust towards the front. The dual ball bearings also allow this fan system to be mounted horizontally or vertically. Its slim low-profile design enables the unit to fit in tight spaces. On the backside are ports to connect and control additional fans. Includes corded power adapter to plug the fan system through an outlet.
Intelligent Programming
Programming includes an easy-to-use thermostat and a SMART mode that automatically adjusts the fan's speed to react to varying temperatures. Additional features include alarm alerts, fan failure triggers, power savings setting, display lock and backup memory. Six fan speeds are available with three screen brightness settings. Behind the unit are ports that can control up to six individual AC Infinity AIRPLATE Cabinet fans and MULTIFAN Component fans.
Design and Construction
Each system features dual-ball bearing fans rated at 67,000 hours and are certified by CE and RoHS. Fans contain a PWM-controlled motor used to minimize noise during speed variations and are suspended in mid-air with silicone mounts to absorb vibrations. A low-profile design allows the unit to fit in applications with a limited height clearance. Aluminum and steel construction enables additional components up to 30 pounds to be stacked on top.
I think I still have the user manual here. If I can't find it I will provide a link to one so you can download it. The original box was discarded upon purchase so this will be shipped well packed in another box so it arrives safe and undamaged to you. Delivery is via your choice of either USPS Ground Advantage, Fedex or UPS and cost will be based on your zip code. PM me with your zip code before purchase to get a shipping quote. Local pickup is also available if you are nearby and want to avoid shipping and save some money. Payment via PayPal only please.
* Please read my entire description and look at the pictures carefully for condition and suitabilty for your needs. Thanks!
Does the heat get exhausted out the front of the unit? I'm looking for something that would go out the rear.
This just sold so I will mark it as such but in answer to your question though, yes this model exhausts the warm air out the front. They also sell models that exhaust out the top and out the rear. If you want rear exhaust check out this one. ;)
Reactions: Foxbat
FOR SALE ECHO SHOW 15
