I'm pretty new to FTA and I got my CS5000 setup yesterday with a SG2100 motor, Invacom QPH-031 LNB and Winegard 31" dish. Luckily, the setup went much better than expected and I'm now getting 12 satellites. Here's my problem: I want to add some transponders to Intelsat Americas 6 at 93.0°W because I've read about all the newsfeeds there. When I originally scanned the transponders supplied with my CS5000 at that location I only got about 20 channels. I then went to Lyngsat to get the transponder info for various feeds. I then went to add them using the "manual scan" mode. I add the transponder freq. # such as 12116 and then I indicate whether the polarity is "V" or "H" (Im not sure if I need to change the symbol rate or not), but when I'm finished there is never any indication of a satellite signal for that transponder and the scan produces nothing. I'm either not inputting the info correctly (most likely) or the transponder info is outdated. Can someone please help me out on this. I blind scanned the satellite yesterday but pulled in many transponders from other satellites close by (apparently). Is there a place to download the latest channel lists for free FTA's with the latest transponders? Thanks!
