Hi everyone,
Like most new people here I'm looking for experienced advice to avoid wasting time and money. Thank you!
I can get about 35 feet off the ground. The good news is, all of the antennas I want to hit are in the same place, within 1 or 2 degrees of each other so I won't need a rotor.
I'm looking at the Channel Master Masterpiece 100, CM 5020, the gain numbers look great and the physical size isn't too huge at 109 inches. I would also add a preamp if needed. See signal analysis below. All of the channels I care about are in the yellow, except WFLA TV 8 which isn't on this map but is in the same area as all the others on the FCC map (RF 7, to become RF 9).
Editing... Tried to post link to my signal analysis from TVFool but suspect that is causing my post to be rejected as spam? I copied the numbers....
Real
Chanel NM PWR Path Distance
32 24.4 -66.4 2edge
10 23.8 -68 1edge
13 21.0 -69.8 1 edge
12 20.8 -70.1 1 edge
Real
32 24.4 -66.4 2edge
10 23.8 -68 1edge
to Satelliteguys FloridaMac!
