albany NY or new york NY? are both of them on in the conus beam?
i input on dishes page the area for both areas and the list for the locals where a little bit different with both of them havin the abc, nbc, cbs, fox, cw in there list.
i would like to know which is the better one or are both the same?
	 cw) on conus beam for sd but if you want HD they are on spot beam only. The two cities are also on different spot beams with NYC being on a couple of different spot beams depending on if you want HD or SD. Also your RSN's would be a little different too.
