AT-9 Mounting Plate Size?
Revenoor
22
Long story and not really relevant but I am being offered at good deal to go to the HR-20. I now have my dishes mounted on the 4X4s supporting a deck and am wondering what the foot print of the plate is, will it work on a single 4x4 or will I need to incorporate an addition surface to mount it on. Does anyone have the dimensions of the bolt pattern or perhaps a template? D's rep was not able to answer when the slim line dish would be available.
The distances between the mounting holes are:
Main mount - bottom
Horizonal: 4 1/2 inches
Vertical: 7 1/2 inches
Top mount
2 bolts centered about 2 inches apart.
Pictured here is my mount.
Thanks for the info. That bolt pattern will not fit the existing 4x4 so I think I'll mount a steel plate there with some countersunk screws and then drill and thread the bolt pattern you supplied for the bottom ( I assume that the main plate has slotted holes, are they all slotted horizontally or 2 horizontal and 2 vertical?). The support won't be an issue.
Help & Guidance in getting DirecTV Part 2
D* Locals guide info?
