AT-9/Slimline mount bolt pattern
Revenoor
22
My install is scheduled to go from the triple LNB dish to the 5 LNB. I've asked the contracting installer every way I know how what dish I will get and what the mounting plate bolt pattern is so I can prep my antenna farm. I typically mount my dishes to the 4x6s (mounted to the 5 1/2" width side) supporting my decks but I am prepared to modify that with a steel plate if required. I have been told the AT-9 has a 4.5" horizontal and 7.5" vertical spacing on the bolts. The installing folks tell me they can not give the dimensions as "every dish is different" I asked the installing contractor to drop off the hardware and I would sign off as if they had performed the install as I do not want them screwing around with my system. They refused. I have bundles with camera feeds, weather stations, networking, etc coming from the "farm". I went thru D as my credits outweigh the cost so I couldn't see ordering from a third party such as Robert. Bottom line: does anyone have the slimline and AT-9 mount bolt patern dimension?
Thanks, Mike
Bengals V Browns in HD?
Does H20 upconvert non-HD channels?
