Audio Out of Sync on Samsung
sklunk
118
129
PA
I recently purchased a Samsung QLED 8-Series. The audio always seems to be out of sync on my Dish feed but none of the other sources. I tried switching the feed to different HDMI input locations, changed audio settings on the TV menu, and played with the audio settings in the Dish menu. Any ideas??
Got to the advanced sound settings on your TV menu. you can set a delay that syncs with the picture. That's what I did to my QLED 8 sync with the sound bar.
Thanks but that's actually the first thing I tried. No soundbar connected -- the audio is directly out of the TV speakers. And the delay setting only works if you use the eARC input (but I tried all the HDMI ports anyway).
There was a similar issue posted recently about the Hopper 3 and Vizio TV's and/or soundbars. (I saw the same thing happen with my ViP211k and my Vizio TV.) Tampa8 posted a solution that seemed to help reduce my audio sync issue:
The audio settings he references are for ViP receivers, but there are similar settings on Hopper, as you can see farther down in the thread. The key seems to be turning "Volume Leveling" off. Another key is to not turn on your Dish receiver until right before you begin watching TV, since the delay seems to get worse the longer the receiver has been left turned on.
This hasn't happened to me lately. (The everyday tv is Vizio with Vizio soundbar and Joey 2.) Just like Crodrules suggested I turn Joey on as soon as tv is on. My old solution in the past was turning Joey off, waiting 3-4 seconds and turning it on. It always fixed the sync issue.
Reactions: pattykay
I have delay issues with my Samsung tv in the master bedroom and the LG soundbar that is connected by optical digital. I have a Joey3 in that room. The delay does indeed get worse the longer you watch. The unfortunate thing is the delay adjustment on the tv goes in the wrong direction and makes it worse. If I turn the tv off and then back on it will fix it for a while but it then gets worse again the longer you watch. I need to look at the back of the soundbar and see if I have the option of going from the Joey3 to the soundbar with HDMI, and then HDMI out of the soundbar to the tv. I doubt it but it has not been high on my priority list lately.
Reactions: pattykay
Newer Samsungs are notorious for this. I can't remember if you have to connect the soundbar to the TV, directly via optical or to the Dish Receiver.
Seems to be a common issue with the Samsung. The video is ahead of the audio. Most audio settings "delay" the audio so any adjustments just make the problem worse. Some channels are worse than others. ABC is the problem for me. Best fix is to turn off dolby digital on your dish receiver and use pcm. While not totally correcting, it helps
Reactions: pattykay
MIne is connected to the TV via optical cable, was hoping that I might be able to connect it by HDMI if there is a passthrough on the soundbar to the TV.
I don't know about Joey 3, but my Joey 2 has only one hdmi input. I assume an hdmi splitter (one for tv and the other for soundbar) will be problematic. Here's the strange thing in my case.
2 identical set up. one in the basement, Vizio tv connected to Joey 2 and Vizio soundbar via optical cable. (Tv volume is completely off, soundbar on. ) Very rarely do I see sync issues when I watch anchorman/woman. Slight delay. I turn off Joey, then on. The problem disappears.
The other setup is in the kitchen. Again Vizio tv, Vizio soundbar and Joey 2. I never encounter any slight audio delay! So, I can't find the reason for sync issues with basement setup. I don't fuss because it scarsely happens.
Thanks for the link to that thread. I had already tried all the connect/disconnect/power off things like you did previously. I also had the volume leveling turned off but I didn't check PCM audio or CEC settings. I'll give those a try tonight.
Reactions: pattykay
I have ordered a HDMI switch so that I can connect everything to the switch (Joey3, Roku 3 and Pioneer BluRay player) and have one HDMI going to the soundbar and then one HDMI from the soundbar to the TV. Right now I have everything going to the TV and then optical out to the soundbar. I want to see if using only the HDMI will eliminate the delay I get using the optical out. I will let you know if it works or not.
So I switched my Hopper audio output to PCM. It seems to help a little but there is still some delay. But it is probably manageable now. Unfortunately I plan on getting a 5.1 soundbar sometime in the future so I really want the Dolby output at that point. We'll cross that bridge when I get there!
Reactions: pattykay
My Samsung QLED is set at "80", which I trust is milliseconds.
Sent from my SM-T290 using Tapatalk
Thanks for the feedback. Switching the Hopper audio output to PCM seemed to have really helped the issue.
Now I just need to work on the judder ....
Reactions: pattykay
How To Record Past Network Shows With OTA
Black News Channel
