I got my AZBox yesterday, and played with it well past my usual bedtime.
I was working with the AZBox editor and trying to figure out an easy way to get the satellites and transponders into a list, and kept seeing the "import satellites.xml" button in the organize Sat & TP tab in the editor.
I spent a few hours trying to take my favorite list out of Channel Master and save it as a Cmproj file which in fact is xml data. It simply wouldn't import the file. I even tried running that file through an xml parser, but still no joy.
Very early this morning I got to thinking about that import button. I knew the programmers had to be thinking of a certain kind of file, but what?
I started a google search on satellites.xml and eventually found a connection with Dream Box. Being somewhat of a Linux guy, I then began searching for that criteria, and eventually found an XML satellite generator.
You can find the generator at Satellites_XML Generator.
Pick out the satellites you want, be sure to pick out the type of channels you want, and if you have C-Band, place a check mark in the bottom to split the satellites into different bands.
It's not perfect, and not all the S2 frequencies are there, but for those of us in NA, it will save us all a ton of data entry with the editor.
It does work with my AZBox, so feel free to give it a try.
There are a lot of steps involved to make the Editor and this work. Our friend Lak7 will be along shortly with a step by step instruction to get the "New List" to work in your AZBox using the editor.
Lak7 and I spent a good bit of time together this morning making sure this all works. I had a heck of a time with the Editor, but finally got it ironed out.
Hope this helps everyone!
