Bandstacked LNBF
1ADAM12
576
10-6 Gas Pumps
Looked in C band FAQ but didn't find topic.
I see Sadoun still sells Bandstacked LNBF, just wondered what satellites do still use C band high frequencies?
Are they used in other parts of the world?
The bandstacked C-band LNBF that Sadoun offers does 3.7-4.2 GHz. Pretty much the same as any other C-band feed. The bandstacking is simply to pass both polarizations down the same cable at the same time.
works really well as long as your receiver can support it.
I had it setup on 4 receivers and it worked great except for the Quali-TV. You cant select a user defined LNB LO so I had to keep it at 5150 and on all horizontal polarity items subtract 600 from the frequency
So World Harvest would be at 3400 H 26400 (instead of 4000 H 26400). If your receiver can support bandstacked, then there is no issues
Pics of my set-up
LNBFs What isn't said on the paperwork.
