Blood and a fantastic signal
PopcornNMore
3,635
128
Gibsonia, PA
Several months ago our 4' Channel Master motorized dish became misaligned during a storm. Due to lack of time and not wanting to miss the Saturday night British shows on Montana PBS (AMC21) I found that if I decreased the declination from 24 to 20 degrees on the SG2100 motor Montana PBS came in clear with a signal of 80% on the Coolsat 4000. For the next several weeks this dish remained at AMC21, because signal from all other satellites was lost. One evening last week I adjusted the declination to 22 degrees and gained back all the other satellites (Amazonas 2 to Galaxy 23) with most channels having a signal of 75% to 80% and enjoyed watching the programming on these satellites once again. However, the signals on Galaxy 18 and AMC21 were weak around 65% with breakups.
Now the story gets better. :) Not wanting to miss the British comedies last night yesterday afternoon while the dish was aimed at AMC21 I went out to the dish with a wrench and loosened the bolts to adjust the declination once again. As I was adjusting it back to 20 degrees the wrench slipped and blood began to pour out of my finger. I tightened the bolts and came in for first aid. To my surprise the signal on Montana PBS was at 87%. I told my wife I was not going to move the dish until after the shows were over last night, because the signal was the best it had ever been. I was also sure that I had lost all the other satellites. When I went back out to the dish to clean up the blood and to bring in the step stool I noticed that the declination was still at 22 degrees. This I found odd, because something must of moved in order to get such a fantastic signal. :confused:
Now the best part of the story. :) After Red Green last night I scanned through all the available satellites from AMC21 to Amazonas 2 and the signals are the BEST they have been in years with most channels having signal strengths between 85% and 90%.
I feel like welding all adjustments (elevation, declination, etc) in place, so that this lasts forever. :)
Sounds like my luck, just when you get everything just perfect and need to tighten up something, I stab a finger or drop the wrench with no possible way to pick it up without loosening the adjustment, haha.
had that happen a few times to me. You try an adjustment, it doesnt work, you adjust it back and it works better :)
I havent busted the knuckles recently with the wrench but my thing is putting it in my mouth when its cold out and having it freeze to the lips ;)
lol, i bet your neighbors really do think you are nuts
i can picture you running inside with a wrench frozen to your lips and sticking out of your mouth to run hot water over it to get it loose
btw, the reason that i know how to get it loose is because ive done that before myself
Something must have changed. Maybe you have a bad/intermittent connector on your cable(s)?
Been there...done that too....ouch. I keep telling myself to quit tweaking things. I get a brainstorm of moving something just a bit and then it gets worse. If I do something totally opposite it usually works. No rhyme or reason..You got to love FTA...hours of fun...hours of frustration lol....Blind
Sky Mexico Transponders
What type of cable to use from actuator to V Box
