Can you mount any TV?
  • WELCOME TO THE NEW SERVER!
HD_Eric
62
Rochester, NY
Specifically, a Toshiba 52HM84. This is a DLP set that weighs 180 pounds. There are brackets (Sanus?) that say they hold this much but I wanted your guy's opinion?
Thanks!
Eric :confused:
I was about to buy this set and i can tell you, frankly 180 lbs is way too heavy to mount! Most mountable hd plasma sets only weigh about 80 to 90 lbs. If I were you I wouldn't even try it! However, that just my 2 cents.:)
I think that TV only weighs about 85 pounds. It should be relatively easy to mount
Your right! Oops my misstake! :p However, looking at the width and depth of this unit, I still wouldnt take that chance! :no
85# is probably wall mountable as long as you had good mounting to the wall studs behind. That would only be 43# per stud if the bracket was 18 inches or wider.
Sanus has a bunch of different brackets that will do up to a 60" TV.
AS toto suggested, a carpenter might put a 2x6 between the studs for more support or if you are a DIY'er, you could attempt it.
I wouldn't mount it over my bed though, just in case... :p
I have the Panasonic 50" DLP and I built mine into a wall. I think at 15 inches deep a DLP unless of the slimmer design is not an eye pleasing thing to mount.
Kryspy
