I live in Indianapoils, IN. My home currently uses an OTA antenna (MANT940) which is routed to a central location and then ditributed to every room.
I have a dish 500 and a DTV tripple phase dish in the garage. I also have plenty of RG6.
My question is how would you configure such a system if you were me?
I was thinking of running a second RG6 cable to each TV location for the satallite feed but later realized that this isn't nessesary. If you had the time and cable would a second cable at each TV be worth it or would you combine OTA and FTA on one cable?
Which satellites would you point your dishes at if you were in my situation? 110 & 119? other satellites?
Which receiver is great for a beginner? I perfer to use a PCI card in my computer because I lean toward my PC replacing my entertainment center by building everything into one box. However, I think I may still want a receiver for TV2 or blindscanning.
Which switch should I use for all those LNBs? Are there certain switches that are compatible with LNBs or is it a matter of the switch must be compatible with the receiver?
Thanks,
freak3dot
Thanks,
freak3dot
