Controlling TV1 and TV2 with more than 1 remote each
morttormjch
6
PA
Is it possible to control TV1 and TV2 with more than 1 UHF remote each? As an example, if I have TV1 wired to a family room tv as well as a bedroom, can I have a UHF remote in the family room and a different UHF remote in the bedroom to control TV1. Similar example also applies to TV2.
If the receiver is setup dual UHF, you can run an infinite amount of remotes off each "TV". The only necessity is to make sure they are addressed to the correct remote address and that range is not an issue.
Do you have the remotes already?
Once you have the receiver setup to receive UHF command on TV1 (TV2 is by default) then just program each additional remote to the proper address after making sure it is in the proper configuration (color keys, remote dependent). Then just hold down the satellite button until the other three mode lights light up, release, enter the address using the number pad, press pound, and the remote should flash three times. Done.
You also want to make sure that you cabled the additional rooms and did the additional modulation for the second TV1
622 - external hd content via DVR recordings menu gone?
Service for a RV?
