Could I use a Phase III DirecTV dish?
igator99
569
Could I use a Phase III DirecTV dish to hit 101,110 & 119 with a Dishnetwork reciver?
I also have a 1998 dual lnb DirecTV dish that I was thinking I could use to hit 129 or 61.5? I'm sure the answer is no but I thought I would ask.
The Phase II will not worl...I'm not getting into why. ...somebody's going to say that I'm wrong, you can use it and give some complicated way...but, I bet you're asking if you can use it for 1119/110, like it works for DTV, and the answer is NO.
The dual LNB you have will work as a "legacy" LNB...it could be used to combine 129 "legacy" style with a SW64, a Dish 500, and 2 more legacy dual LNBs and a Dish 500.
That's what I figured. Thank you for the information.
The Phase III won't work for Dish Network due to the built in switch which Dish uses different switching than DirecTV does :)
The phase 3 will work with one orbital slot only with Directv and Dish Network. You have to use the first input on the lnbf but cannot be connected to switches to work with other dishes and you can only get it to work with one receiver/ one tuner, is that correct?
Unh. Maybe, but it's just going to be a lot of trouble.
LNBs and pans (D* or E*) just aren't that expensive most of the time. Maybe you can make a swap deal with someone. I know I wouldn't have a problem giving someone a D500 with a Twin in trade for a Phase III (maybe plus $10 for the trouble).
Good Installer for new customer - Baltimore Area
Lesbian kiss on family package?
