Datron semi automatic seeking antenna on motorhome
dondonohoo
I have a Datron semiautomatic antenna that takes a low speed data cable. Currently I have Direct TV. Does Dish TV have a receiver that will work with this antenna?
o, and if you only have one wire coming from the dish, then you cant use any of the dual-tuner dish receivers, just the single tuners.
I also have a Datron on my MH. I have done LOTS of research, and it appears that Dish does not have a receiver with a low speed data port. This is where the Datron plugs in. Good news, however, it seems there are a lot of later model Sony DirectTv receivers that have the data port. But, I can't say which, if any, other than the Sony Sat-A4 will work.
5-07-08 HD Rumors.
Inquiry about TV programming
