Different Freq than Lyngsat when scanning
kelleyga
320
I have a Pansat 3500, 10 Foot mesh dish. WHen I scan a satellite I get all channel listed in lyngsat even some extras. The only thing is that it shows different FREQ in my Pansat.
Example a channel in Lyngsat may show 11745 and when scanned in my pansat it will show it as 11746. THe SR stays the same. It happens a lot in several different satellites. So if for example I want to enter it manually then sometimes it will not work, because the pansat does not see it as lyngsat. It will be usually one - or +.
I am just wondering why that happens and if I need to change something in my setting or if it is just the Pansat Receiver.
THanks for your help.
When scanning it stops as soon as it gets a signal, so that sometimes happens as above just before/after where the actual signal is, many times manually changing it will help.
Also happens as all LNB's are slightly off Freq. and to each other.
its perfectly normal
When I scan SBS6, I get ONN at 11740, 11741 or 11742 (I think they are at 11742)
Amc4 Ku
G10r's 11720V = WOW!
