1. Another Team Summit in the books!
    Thanks to the generosity of a number of our members SatelliteGuys will be covering DISH Networks Team Summit Event from Phoenix, Arizona!
    CLICK HERE for our Team Summit 2019 Coverage!
    CLICK HERE to see our 2019 DISH Team Summit Recap Video! Thanks for being part of SatelliteGuys!
    Dismiss Notice
DirecTV Local Channels Detroit Spot Beam Radius - Ontario, Canada Area Cottage
Discussion in 'DIRECTV Support Forum' started by Amer Q., May 12, 2019.
  1. Amer Q.
    Amer Q. Topic Starter Member
    May 12, 2019
    7
    Detroit
    Travel to cottage northeast of Toronto - Uxbridge, Ontario, Canada to be exact.
    Google Maps
    *Know if I would get my DirecTV Detroit local channels up there? How wide is the spot beam? Considering setting a dish up there and bringing my receiver up.
    Thanks!
  2. comp9
    comp9 SatelliteGuys Pro
    Jan 24, 2017
    460
    139
    PA
    It isn’t that wide. That may be too far for Buffalo also
  3. Jimbo
    Jimbo SatelliteGuys Master
    Jul 14, 2005
    60,143
    2,437
    NW Ohio - Buckeye Country
    The Detroit local use to cover a larger area, to Cleveland, Cincy, Indy and Detroit, but that was back in the day ... before Spot Beams ...
  4. Amer Q.
    May 12, 2019
    7
    Detroit
    Do you have a map that shows the Detroit spot beam coverage area? Wondering if it covers the Toronto surrounding area
  5. raoul5788
    raoul5788 Studebaker driver
    Staff Member HERE TO HELP YOU! Supporting Founder Lifetime Supporter
    Dec 28, 2004
    27,178
    10,195
    Cheshire CT
    You should be able to get reception in Toronto. Weather could be a factor at times.
  6. nelson61
    nelson61 SatelliteGuys Master
    Dec 8, 2007
    5,488
    4,206
    Where it's Warm
    Any area above something like 48-50 dbw should have good signal if they have not dialed down the power on that transponder.
    KML, KMZ Viewer with Drive
  7. Claude Greiner
    Claude Greiner SatelliteGuys Master
    Sep 8, 2003
    11,981
    2,922
    Detroit - The Paris of the Midwest
    I know Detroit won’t hit Chicago. It works a bit further north than Tawas Mi and all the way to Cleveland.
    The beam is pretty wide, but I doubt it hits north of Toronto
    comp9 likes this.
  8. raoul5788
    Dec 28, 2004
    27,178
    10,195
    Cheshire CT
    Toronto shows a signal strength of 53.5 dBW, plenty strong enough for consistent reception. Chicago is at 44.5 dBW, receivable but flaky most likely.
  9. Claude Greiner
    Sep 8, 2003
    11,981
    2,922
    Chicago is a definite no!
    I had an office down there and we tried to use our showroom demo box from Detroit.
    I finally had to update the address with directv to get Chicago
Separate names with a comma.
More...
