Directv remote codes for Yamaha HTR 5790 AV Receiver
Bosco10021
163
At the beach
I have a Yamaha HTR 5790 AV Receiver.
I recently decided to try to have my Directv H21 remote control the Yamaha's volume and power.
I tried all the codes that I could find but with no luck.
Does anyone have one of these working with their Directv setup ?
If so would you please share a remote control code that works.
You will not find one code that powers the receiver both ON & OFF, not with yamahas use of a two-key power scheme and the lone power key on the white remotes. One of the commands will always be missing.
To get the volume, use code 30176, yes the volume keys NEVER work initially with ANY audio code, not until you do the following. First there HAS to be a tv code programmed to the tv device or the volume keys won't work at all. Then:
1. av1 or av2 whichever has the yamaha code
2. press and hold MUTE & SELECT for two blinks
3. enter 9 9 3
4. press SELECT
Will D* require me to extend my contract?
Help! SWM 5 LNB Slimline Install Problems!
