Can it be done through either the visible or hidden menu?
A couple of days ago, I connected satellite input #1 of an R15 to a stacked LNB line, but it couldn't figure out what it was connected to. Then, I went into the hidden menu ("action" and "right arrow", I believe) and set it to "stacked" LNB mode and successfully ran through the set-up.
While I was doing some work elsewhere in the building (large MDU), but before I went to my truck to get a high frequency splitter for the second input, the receiver would display a message indicating that there was no satellite signal on input #2 while allowing the tuned program to be viewed, and it would eventually go into "screen saver mode" (bouncing blue DirecTV logo). Once I installed the splitter, that annoying symptom went away, so I never had to poke through the menus looking for a way to disable the second satellite input.
Today, a DirecTV installer tried to install an R15 in another MDU in which I installed the master antenna system, but this time, it is a simple Sat A multiswitch system, with just one home run per apartment. The installer was unable to make the "searching for signal" notice go away, and he told the customer that he was not allowed to leave the receiver there if the installation was unsuccessful, so he took it with him.
Tonight, I found a way to run a second coax to allow the system to fully support two tuners, and so the DirecTV installer will be bringing the receiver back once I confirm that the second wire has been run, but for my future edification, how does one deliberately disable the second tuner? In a related thread it was reported that the receiver automatically disables the second tuner if it sees no signal there during setup, but that was not the case in either of these installations.
