Dish 1000.4 footplate
TLaz
25
Would it be safe to replace a Dish 500 with a Dish 1000.4 using the same mounting pole and footplate?
As you may know, the 1000.4 uses struts to stabilize the dish. I suppose that if the 500 mast diameter is the same, it could work, using the supplied struts. I think that the 1000.4 mast is somewhat longer.
The 1000.4 is larger and heaver then a 500
That said if it is in an area sheltered from the wind and propperly mounted in the first place (six lag bolts ect.) then you could re-use the mast
The .4 mast is longer to allow for wall mounting at 90 degree angels
I installed my 1000.4 sat dish on the same pole in the ground I had my 1000.2 sat dish on and the dish 500 before. I don't use the struts at all. It works just fine with great signals:
72.7 sat - between 60 - 70
77 sat - between 50 - 56
61.5 sat - between 45 - 70
Yes..Both will fit. All Dish network antennas use the 1.66" outside diameter mast. Put the 500 dish right on there. No worries.
AAD and "Moving "
Receiver Solution for 3 HDTVs
