Dish 1000+
elwood2083
OK I need some major help help here....I am injstalling a 1000+ for south asian cahnnels (118) and also HD (129) I have a 500+ 118/119 LNB and one single DPP and a dual DPP...also have a DPP 44 installed....I can see sig off of lnb on my birdog for 118, but when I check swithch it...its say connection four on the 1st tuner (722) has good connection no sig...tuner 2 has N.C....also using a seperator...HELP HELP HELP!!!!! oh yeah I get 110,119,&129 all with good signal
118 is showing on tuner 1, but not on tuner 2????
If so, I'd say, "piss on it", and finish the download and then re-run the checkswitch to see if the 118 does come in. If it doesn't, then eliminate the usual suspect (i.e. defective separator) by trying to swap out said separator.
Well it dosent show siganl, but shows connection on tuner 1.....now I took all diplexers, and serperator out ran Check switch with straight in cable to tuner 1 and it yielded the same reslut no 118
first impression to me says - aiming.
things to check:
power inserter on output PORT 1 on the DPP 44 connected properly to switch, Receiver, and AC power?
any unrated barrels anywhere in the line?
what transponder at the Dish are you checking for on 118? whats the signal strength?
DP721 No Switch with DP Quad
Does my bill look correct?
