Are 105 and 121 still used by dish?Those are all circular polarity. 118W is also circular but a different frequency range. Dish has two locations, 105W and 121W which use linear polarity.
121 is business associated, 105, internet?Are 105 and 121 still used by dish?
Thought they were long gone?
Sure there is. Here you go:So I take it there is not an updated channel by satellite list available?
Or, while you are tuned to a channel, simply press the Info button twice, and there should be a little icon in the program info box that tells you which satellite that channel is on....
By selecting channels and then signal meter screen I think I've figured out how to indirectly select 110, 119, 129,
Would that hold true?
Playing with a backup Dish 500 and a 211k, realizing Most (but not all?) HD is on 129 I think.
For the Hopper 3 press Info button then press the recall button to see what satellite your channel is on.Sure there is. Here you go:
DISH Network Channels by Transponder (Unofficial Listing)
uplink.jameslong.nameDISH Network Channels by Transponder (Unofficial Listing)
Or, while you are tuned to a channel, simply press the Info button twice, and there should be a little icon in the program info box that tells you which satellite that channel is on.![]()
That works in the Hopper interface. ViP211k is different. Info - Info works on ViP's.For the Hopper 3 press Info button then press the recall button to see what satellite your channel is on.
