Dish pointing problems
crhea
4
Minnesota
I'm an old C-band sat guy trying to do a self-install of a 1000.2/VIP922 using an Accutrac III+.
Connected to port 1 on the 3LNB and peaked. I've got 70 strength on Sat 129, 54 on Sat 119 (both on T21), but when I select 110, it says: Wrong Sat: Echostar 129 W.
The Check Switch only shows 129 on #1, 119 on #2 and CONN on #3.
I'm thinking I'm pointing too far West and have the sats on the wrong horns-- is the "Wrong Sat" message just an artifact of how the switch works?
Sorry if this is a dumb question-- new to the Dish Network/multi-LNB game.
Nevermind...
Yup... that was it. Went out this morning and moved the dish East... then made sure I had
119 on the center horn.
Duh!
Cute way to MAKE SURE it's on the right horn...
Since I got burned with the sat getting picked up on the wrong horn, I did a quick-n-dirty to MAKE SURE I had it right:
Leave the center horn alone, and cover the other two with a small piece of tin foil. Then see that the receiver:
1. Gets signal on the 119 sat.
2. Identifies the sat correctly.
Again, I was working with a 1000.2 (110/119/129) dish and peaking on the 119 sat. Obviously,
you'd change this if you're searching for/peaking on the 129, as one poster mentioned.
Satelite 129 problems on dish 1000.2 Vip 211 tuner
DISH Network ViP 222K High-Definition
