DISH to DTV Mounting ?
tmikeb
23
I am considering a move. The prospective condo already has a Dish Networks dish installed. Can DTV use the same mount to convert. I am thinking the landlord may not want additional holes drilled in his unit.
Usually the mounts are different in size.
Does it have to be on the roof or will a Pole mount do ?
It has a roof top mount due to obstructions. I was wondering if you could actually slip the Dish Dish off and slide on the DTV Dish? One reason is to avoid putting more holes in someone elses roof.
Unfortunatly the footprint of the bases are not the same.
I would recommend removing the DISH one and place the new one with roofing cement under it.
Thinking about returning to D
Channel requests?
