Does anyone know what is up with the "EXT" button for recording? I cannot seem to record directly to my External Hard Drive using that option.
The CSR'S are clueless!
Do you have any problems with playback on the External HDD? It keeps freezing up on some playback of my movies...........no all of them but when I FF them it than gets stuck....also this is my 2nd brand new one Western 750GB. My book essential edition. I have to unplug it and then repower it to get it unstuck....only on some of my transfers.
How come FTA boxes can record/playback from the usb drive, but dish cant?
I think the Dish programmers are only using the slower normal speed mode of the USB 2.0 port and not the high speed mode. Data transport takes a lot longer than it should.How come FTA boxes can record/playback from the usb drive, but dish cant?
Because they don't have the ability to do 5 streams like a 622 can. They also don't (AFAIK) have the trick modes.
It is mostly Cinemax and some MGM and some HDNET Movies.....that's about it No over the air. Whenever I Fast Forward It freezes up and is then useless. I unplug my Drive and power it back up sometimes it is fixed but if I use the Fast Forward again it does the same thing...sometimes I lose the whole Program.Can you determine if those that freeze are OTA, Dish MPEG2, or Dish MPEG4 or is it a mix of those formats?
Sounds like a bad drive / external case. There's no rhyme or reason to the errors. Your first drive works fine? I'd move stuff off this bad drive, format it and scan it on a pc and then plug and initialize it again on the DVR and see what happens.It is mostly Cinemax and some MGM and some HDNET Movies.....that's about it No over the air. Whenever I Fast Forward It freezes up and is then useless. I unplug my Drive and power it back up sometimes it is fixed but if I use the Fast Forward again it does the same thing...sometimes I lose the whole Program.
What kind of drive do you have? I may take this one back again and get my money back. I cannot believe it happened twice with my brand new drives!There certainly is a problem - our external drive works just fine.
--Doug
