DishPro Plus lnb work with DP 301?
monkeymail
Feb 6, 2006
Hi
I have been having problems with my system. Before I moved, everything was working fine. When I moved, I do not get all the channels that I Pay for. Something happened to the dish. The reason I say dish, is because I took my receiver to a friend's house and plugged it in to his dish and everything worked. I went back to my home and plugged the receiver back in and went to the "Installation/Setup", "Point Dish/Signal", Check Switch" and tested it. It listed that 119 is "Odd", but 110 switches between saying "Odd" and "All" and never "Even" when I test it. So I know that in the Lnb, the switch will not work correctly. So, I would like to trade me DishPro Lnb for the newer DishPro Plus Lnb. I think that this newer Lnb will work with the older DP 301 receiver, but I am not sure, so if anyone knows, please reply!
Thank you for your time!!!
bill93civic
158
Kingman, AZ.
yes, the DishProPlus lnb will work with your 301, youll just have to run a switch check after it replaces the DishPro lnb.
<edit> unless youre using a DishPro quad lnb, than youll need to replace it with another DishPro quad
What will my service cost
Faint horizontal line when in dual mode?
