DIY Slimline 3 install - questions?
quaffin1
17
Hey guys:
I plan to install a Slimline 3 SWM dish at my vacation cabin.
I just purchased the SL3 SWM model dish.
My question is what other items would I need to make this install go simpler.
I will need 2" diameter pole, understand this is not usually found at places like
HomeDepot or Lowes. Have heard muffler shop is good place to get one cut?
For Dish alignment, I see many cheap analog signal meters showing on Eb**
most are $10-$20. Will one of these be an aid for alignment or just a waste.
I don't really want to buy a $200 meter like the pros use, for this onetime install.
I see most of these cheap signal meters, need the receiver hooked up for the DC power. Some are available with a battery pack for slightly more $.
Is there a better way? or a better cheap meter. I don't mind paying up
to $40-50, or so.
Also the installer used a 4way splitter mounted to the house, since I was having two rcvrs installed. He used 4 way splitter #MSPLIT4R0-03.
Should I order this splitter for connection and grounding before going into the house, even tho I will only have one line going into house, at least at this time?
I will only be using one standard HD rcvr H23NC-600. But could be moving here in a year or so and upgrading to 2 rcvrs.
Any tips or suggestions will be appreciated.
Hey guys:
to $40-50, or so.
Also try a Fence company for the post.
I personally would skip the meter.
I would practice setting it up at home, so you have a reference point.
No Multiswitch needed if you have the LNB set up that has 4 ports available, run 2 to each recvr.
Hey guys:
to $40-50, or so.
I don't know why he installed a splitter if you have two receivers, but that doesn't matter at your vacation house. You won't need a splitter there since you are only using one receiver.
I was about to say remember a BBC converter, but if I recall the H23 has it built in.
Remember in the satellite setup to select the Slimline 3, the one in the 4-5 range, not the ones in double digits (those are the SWM).
Skip the meter, use the receiver. Get 101 in the 90+ range, then just tweak 99/103 till both are in the 85+ range.
The op said he has a SWM dish, so he would need to select that one in the setup, yes?
Your right, I missed that, he'll need the one in the list at the end Slimline 3 (SWM) I think it is 17 or 18 or so.
How about don't forget the power inserter then :)
DirecTV starts Multi-Room Viewing MRV field installs in 4 markets
DIRECTV to Launch ESPN 3D to Millions of Customers Nationwide
