I recently purchased an Amiko Mini H265, which arrived yesterday. I've been using an Amiko DM3800 motor since October 2020 and it has worked great. However, yesterday, something happened. When I connected the coaxial cable to the Amiko, everything was working fine. About 15 minutes afterward, I noticed that, when switching satellites, I would get no signal. When I would go back to the previous satellite, the signal would show up right away, meaning that the motor wasn't moving the dish.
I worked nearly all day yesterday to figure out the problem, but I'm running out of ideas. I noticed that, when moving the cable running from the motor to the receiver, the LEDs on the motor would gradually brighten and dim as the cable was moved/twisted. Sometimes, the motor would make a clicking sound and the LEDs will flash normally, which shows that there is adequate power, but this was only brief. If there was adequate power, the motor would move the dish slowly before coming to a stop, almost like it's losing power or there's a weak power source.
Today, I replaced the main cable running from the motor to the outside edge of the house (there are three cables connected together with cable extension adapters). At first, it looks like there is adequate power to the motor. The LEDs flash a few times, which is normal. Moving the dish, however, still doesn't work. It'll sometimes move the dish, but very slowly.
I find it coincidental that this issue happened as soon as I got a new receiver. Granted, the motor was moving the dish slowly beforehand. What could the problem be? It could still be a cable issue, which might be the most likely issue, but I'm afraid it's a problem with the motor.
