Do I have this correct???
ashutto20
1,255
85
United States
I know Cbs can go over on Sundays therefore pushing back its lineup on Sunday...
I have set a manual timer for the 10pm show tonight and have extended the time past the alloted 5 mins given to PTAT...
It shows up skipped in my daily schedule...since its the last show of the night on Cbs I need to unskip it???...will it still only use 1 tuner or 2 tuners if I unskip it???
Thanks in advance...i just wanted to be 100% sure
I think it will use an additional tuner separate from the PTA tuner but unskiping it is the only way to get the extra time.
No extra tuner, it just creates a pointer to save the show after the 8 days and you'll get the 5 minutes from PTAT. If you want more than 5 minutes, edit the timer AND skip. It will then use a tuner. If you don't skip, only the PTAT version will be saved.
Would you pay attention to what the H*** you're saying. First you say it does not then you say it does.
If a timer for a PTA show is unskipped a second tuner WILL be used.
Tip: Changing Joey Pairing in a Two Hopper System
DNLA solution -out of the ordinary
