dtv south of the border.
Discussion in 'DIRECTV Support Forum' started by prop, Dec 8, 2018.
  1. prop
    prop Topic Starter SatelliteGuys Family
    Jan 8, 2009
    65
    mexico
    i spend the winters in southern mexico and have been getting most of the 101 transponders with a 10 ft dish down here.i heard that people were losing channels here.when i got back here this week i tried setting up my dish and i`m only getting 18 transponders.i use to get 24.of the 18 i get ,the signal is over 90 on most of them,i always bring one of my ird`s back and forth it`s a hr24 500.i can`t get the settings to change to a single 18 round dish.it says no sat signal detected and then the guide will load to 98% but then stops.tried using swm switch and still no good.it`s just about impossible to get 103 and 99 sat here so i`m stuck.i never had any problems resetting the ird to 18 round in the past,is it because i`m only getting 18 transponders?any ideas?thanks for any help
  2. nelson61
    nelson61 SatelliteGuys Master
    Dec 8, 2007
    5,245
    3,979
    Where it's Warm
    The guys at the edgecutter forum will know why. They are deep into DirecTV satellites.
    Sent from my SM-G955U1 using the SatelliteGuys app!
  3. ejb1980
    ejb1980 SatelliteGuys Pro
    Oct 26, 2010
    3,133
    459
    Vermont
    If you're using MPEG2 channels, don't bother trying to get them back. All MPEG2 is going away "soon" (2019) and you'll get nothing after that... sorry. MPEG2 is basically SD on 101.
  4. slice1900
    slice1900 SatelliteGuys Pro
    Feb 14, 2015
    610
    213
    IA
    I assume you've lost many of the odd transponders? That's because Directv switched satellites for the odd transponders at 101. Next year they will switch for the even transponders as well, and you will probably not be able to receive anything at all from your location. You need to begin looking for another option, using Directv USA there is not going to work any longer.
  5. prop
    Jan 8, 2009
    65
    mexico
    yeah i kinds figured that.but won`t there be another sat at 101 for the ka band transponders?
  6. slice1900
    Feb 14, 2015
    610
    213
    IA
    No, Directv isn't using Ka band from 101. They have a license for it, but have never used it for customers and never will - they'd need new LNBs designed to pick that up. They don't need the bandwidth, so no reason to bother with it.
  7. prop
    Jan 8, 2009
    65
    mexico
    so there will be another sat at 101 that is ka along with 103 and 99?
  8. raoul5788
    raoul5788 Studebaker driver
    Staff Member HERE TO HELP YOU! Supporting Founder Lifetime Supporter
    Dec 28, 2004
    26,524
    9,235
    Cheshire CT
    No. They will convert the encoding to mpeg4 instead of mpeg2, but it will still be ku band.
  9. prop
    Jan 8, 2009
    65
    mexico
    i trying to understand what is going on with 101.i get that all the sd 101 will be gone.so the 101 will be all mpeg 4 hd?i guess the beam will be a lot tighter and not available here?thanks for the help ,i`m just trying to understand whats going on
  10. slice1900
    Feb 14, 2015
    610
    213
    IA
    101 will have some MPEG4 HD and some MPEG4 SD. As 99 & 103 already do today. It is possible there may be a few MPEG2 SD channels left, for stuff where it doesn't matter like the slates (i.e. 950x polarity test) or music channels.
    The beam's shape has nothing to do with whether a satellite is carrying MPEG2 or MPEG4, or HD or SD. It has to do with the satellite's antenna. The antenna is different on the new satellite at 101 than the older ones. One of those older satellites has been replaced by the new satellite (T15) the other older one will also be replaced by T15 next year (T15 and T16 may swap, but they are basically twins so it won't matter) Then you probably won't be able to receive anything from 101 at all. You will need a new provider in Mexico, using Directv from the US simply will not be possible at all.
  11. prop
    Jan 8, 2009
    65
    mexico
    i was told by a local installer that i would get most of the tp`s between 12 and 2 at night.i was skeptical but it`s true.last night at 12:30 i got all but 6 tp`s and was able to change my setup to 18 round and the guide loaded and,i got most channels.i did lose some this morning but still get cbs local from ny.the other locals will only come in after midnight.is the signal stronger at night?i just trying to figure it out.
  12. nelson61
    Dec 8, 2007
    5,245
    3,979
    Where it's Warm
    You can switch to Dish and use one of their little red Mexican 18 inch dishes with a US box. you will get most everything in SD with the all the local and national channels from 8 or so eastern cities in HD.
  13. prop
    Jan 8, 2009
    65
    mexico
    i was asking about that but i was told it won`t work here.i`m about as far south that you can go in mexico,about 15.6 north and 97 west.i looked on the coverage maps but i don`t know is an 18" dish will do it.i have a 10 ft solid offset dish that i use for the dtv and 2 other 6 ft dishes also.are the dish lnb`s similar to dtv?
  14. slice1900
    Feb 14, 2015
    610
    213
    IA
    I'm amazed you are able to pick up anything from Directv way down there!
  15. nelson61
    Dec 8, 2007
    5,245
    3,979
    Where it's Warm
    You are getting bad advice.
    Quetzat 1 has excellent coverage all the way down through Panama and into the edge of South America.
    Mexico has a very high signal strength with the entire country within the -53 db range. It uses a very small antenna for reception anywhere in the continental US and Mexico
    The red 18-20 inch Dish antenna is using Quetzat but different transponders than those used in the United States. So, if you see one of those red antennas in your area, they are receiving Quetzat signal.
    It does not transmit the extended time channel guide nor does it transmit activation codes so the box needs to be activated at a location that has reception from one of their other satellites.
  16. nelson61
    Dec 8, 2007
    5,245
    3,979
    Where it's Warm
    Dish uses a different lnb
  17. prop
    Jan 8, 2009
    65
    mexico
    so i could set it up in the usa then bring the box down here and basically use the same dish as in the usa?
  18. nelson61
    Dec 8, 2007
    5,245
    3,979
    Where it's Warm
    Be cheaper to have the box activated up north on someone's existing setup (but in your name) or by one of the dish on line vendors.
    Then you only need to transport the box.
    Then buy your Dish and lnb locally.
    Here's an example of dish and lnb that you can get delivered right to your home for less than $20 US.
    Antena Dish Completa Con Lnb Dual Nueva - $ 330.00
  19. prop
    Jan 8, 2009
    65
    mexico
    so that lnb will pickup hd channels also?can you recommend a dish online vendor?
  20. nelson61
    Dec 8, 2007
    5,245
    3,979
    Where it's Warm
    Dishdepot.com has good prices and service.
    The lnb works on all channels.
    Use James Longs excellent site to see and choose one of the available cities. The local channels in each city are listed there.
    DISH Network Channels by Transponder (Unofficial Listing)
Separate names with a comma.
More...
