I have a dual tuner OTA Adapter hooked up to a Hopper 3, however I'm only getting one tuner. Is the 2nd tuner active, or could is it in a software version that my H3 doesn't have? (I don't know what it has now, I've only had it for 3 weeks.)
Both my H3's dual OTA adapters are working ok. I can see two OTA channels on each H3.I have a dual tuner OTA Adapter hooked up to a Hopper 3, however I'm only getting one tuner. Is the 2nd tuner active, or could is it in a software version that my H3 doesn't have? (I don't know what it has now, I've only had it for 3 weeks.)
Where/Who did you buy it from? .I have a dual tuner OTA Adapter hooked up to a Hopper 3, however I'm only getting one tuner. Is the 2nd tuner active, or could is it in a software version that my H3 doesn't have? (I don't know what it has now, I've only had it for 3 weeks.)
You most likely don't have the update that accommodates the dual tuner dongle. Check to see what update you have and if necessary, force the latest update.I have a dual tuner OTA Adapter hooked up to a Hopper 3, however I'm only getting one tuner. Is the 2nd tuner active, or could is it in a software version that my H3 doesn't have? (I don't know what it has now, I've only had it for 3 weeks.)
Is it hot, or quite warm, to the touch?
The U235, or higher.What is the software version required for the dual ota to function on HWS?
I'm on U348. How do I force an update?
menu 2 times (the 40.0 remote does not have a home button)If you have the new 52.0 remote hit the home button 3 times to reach the diagnostics menu. From there go to tools and then update hopper.
With the 40.0 remote I think you just hit home 2 times to get to the diagnostics menu. I'm sure if I'm wrong on the 40.0 remote someone will correct me.
