Jww,
Those are interesting options. Since I don't have Enigma installed, I don't know. But, I am quite curious.
I wonder if FAST DiSEqC has to deal with the step speed when initially searching for a sat or if it has to deal with slew speed when commanding the system to move from one sat to the next in TV viewing mode. You know that when you select a channel that is on a horizontal TP, 18 volts DC is applied to the motor to drive it. If the channel you select is on a vertical TP, only 13 volts is applied. Therefore, the motor drives to the new satellite faster when a horizontal signal is requested. I wonder if they programmed the system to apply 18 volts (in FAST DiSEqC mode) to make the dish drive to the new sat faster, regardless of what TP polarity was selected?
No idea about the power measurement feature. I wonder if it could have anything to do with monitoring the motor current, like for setting up the backlash adjustment?
Since these options are within the motor setup menu, I can only imagine that it must be related to some similar feature. Just off the top of my head, these are the things that I could see that would be a valued perk. I wonder what they are really for.
RADAR
