FTA and Diplexer with CATV
Wescopc
1,900
211
Canby, Oregon
Does a diplexer work with cable TV and the KU band? I have never tried using a diplexer, I think they are designed for OTA signals. So I would like to hear from someone - do they work? And how well.
Bob
yes it will work. Diplexer works from 35-approx 900mhz on the OTA/cable end and cable is between 54-600 mhz usually.
The only time it wouldnt work is to combine 2 satellite signals. We used a diplexer to combine a cable line and a directv line into a room and had no issues
Thanks Tony - I will give it a try, after I order some diplexers.
Bob
Bob
I do this for one of the rooms in my house which has digital cable and can see no degradation on either analog or digital cable nor satellite.
A diplexer will introduce approximately 1.5dB loss for each insertion. This totals to a 3dB loss for the merge and separation.
3dB loss can eliminate weaker signals. I personally avoid diplexers for typical FTA installs with a 76 or 90cm dish.
That is good to know - thanks Brian.
Bob
yeah that is good to know. I use to have my Starchoice output diplexed into my FTA line for the compauter room but removed that a while back.
Guess I'll have to run a 2nd line in there :)
Fortec Passion
One simple question about LNB settings
