Gain of Dish antennae
sprprsnmn
72
What is the difference in gain of a Dish 500 and a Dish 1000? Is a Dish 1000 a huge improvement over the Dish 500?
Your question is really incorrect, the 1000 is designed to receive signals from 3 satellite locations not to increase the satellite signal from one location. It is a compromise to get the most from the smallest dish. If you want more gain from 119 use a 24" single satellite dish. The same for 129, if you want to maximize the 110/119/129 reception use a Dish 500 for 110/119 and a 20" or 24" separate dish for 129.
Thanks! I was planning on using a second dish for 129/61.5 (whichever I get a better signal to) so I'll just go with a 500 for 110/119.
There is not any standard numbers in use. Up until this point, Dish has used a different scale on different receivers, making comparisons difficult.
Coincidentally, right now, Dish is changing all the receivers to a standard scale of signal strength numbers that will be more useful.
To answer the original question, Dish 500 gives more gain on 110 and 119 than Dish 1000, the latter adds a third location at the expense of a slight decrease in 110 and 119.
You don't mention your location which is the crucial factor for both 129 and 61.5 . Generally, if you can get a clear sight of the 61.5 satellite, it gives you a better signal strength than 129. But, Dish considers 129 the standard location for HD, although so far, all HD channels are mirrored on 61.5 .
If you are in the NorthWest, then a 24-inch dish for 129 is recommended, and a 30-inch dish is ideal (the Winegard DS-2077 30-inch can be purchased for around $50, and is the same brand who makes dishes for Dish Network).
Elsewhere, a second Dish-500 for 129 or 61.5 is an ideal solution, because you can get a Dish-500 on ebay for very little $$.
My location is 71118. 32.397664 N, 93.802543 W.
Is it true that with circular LNBFs, you don't have to set the skew?
TV interference?
WNNE off air in Burlington VT locals package.
