give me a gun!!!!!!!!!!!!!!!!
trauts
4
i have been trying to install a supdish to get locals. i have a 3800 with a sw21 and when i do a switch check i get...
119 X 110 110
even X even odd
so i read i needed a dishpro adapter, so i purchased one and install it and now i get...
119 119 x x
even odd x x
i need help
dp34 bad
the dp 34 out of the box was non-funtional- counldn't get a signal, i'm pretty sure i had it all hooked up right i just used the sw21 stright of the lnb to get some tv period i'm trying to get another dp34
------------------110
l
l
l
------------------119
l
l
l
------------------105
l l l l
l l l l
l l l l
tv tv tv tv
looked like this but just no signal from switch
that little diagram got all screwy
i was trying to show how i hooked it up but it didn't turn out that way
I haven't figured out your diagram but until you put a DP-34 in the system all you can get is 1 satellite, so put it on hold until you get a DP-34. :)
Did you try to use the DP-34 switch before using the DishPro Adapter? If so that would explain why the DP-34 switch would not work.
thanks guys for the input, i wasn't sure what the gu helping me said the problem was but i may try the 34 tomorrow, myself so i can explain exactly whats happpening.
thanks again
comcast ads?
dish pointing HELP
