H10 receiver trouble
satrick
On reboot I get "finding sattelites failed". I have performed the system self-test and it shows "receiver failure" and "LNB Failure". I am showing signal on the signal meter for various transponders in system setup. I have repaired any possible connection issues with the cable. Other receivers (not HD) work fine on this run, I get the same error message when I use this HD receiver on another room's cable. I have also switched the connections from the LNB to make sure I had signal from each.
I am assuming the receiver is bad. Any suggestions?
Directv: How do I get the networks? Good 'remote' address?
Summer Home With Same Subscription
