We will again be participating in the HamVention in Dayton. Check out some of our specials on our website and read about upcomming shows we will be attending. Here is a sample:
B1SAT STACK C-Band LNBF Without Scalar
Pro Brand - Eagle Aspen
Blowout Sale
$19.00
This LNBF is used for the C-band digital / analog satellite signal. It can be mounted on any Prime focus dish using a standard scalar ring and mounting screws (not included). LNB is designed for reception of signals in C-Band frequency range between 3.7 and 4.2 GHz. Ideally suited for reception of U.S. satellites.
Special for Digital C-Band Satellite Reception
Extended Frequency 3.7 GHz ~ 4.2 GHz
Voltage-Controlled H/V Switching (13/18V)
High Gain Output
Light Weight Design
100% Waterproof
Scalar Ring is not included. Fits on a standard Scalar Ring
Model Number B1SAT STACK
I/P Frequency 3.7-4.2 GHz
O/P Frequency 950-2050 MHz
LO Frequency Lower Band 5.15 GHz, Upper Band 5.75 GHz
Output Connector Type "F" Female Connector
LO Initial Accuracy ± 1MHz @ 25° C
Stability (-35°C to +52°C) ± 2.0 MHz
LO Phase Noise -60 dBc/Hz (@1kHz)
-80 dBc/Hz (@10kHz)
-90 dBc/Hz (@100kHz)
Noise Temperature 17 °K
Crosspol Isolation 20 dB
Conversion Gain 62 - 68 dB
Gain Flatness ± 0.5 dB /27 MHz
Image Rejection 40dB (min.)
Third Order Inter modulation -50 dBc (min.)
1 dB Compression Point 0 dBm
DC Voltage 10 – 24 VDC (supplied by receiver through coaxial cable)
Output Impedance 75 W F-Female
Output VSWR 2.5 : 1
Blowout Sale
$19.00
High Gain Output
Light Weight Design
100% Waterproof
-80 dBc/Hz (@10kHz)
Output VSWR 2.5 : 1
