Having problems with G10
joem919
161
myrtle beach
iceberg hows this for a rookie with a bad system ,im doing a blind scan on supposelingly g 10 and so far 4 transponders dont know whats on em their comeing up 11794 v 19700
to 11823 h 5,700 and its still scanning tv latino and tv english definitly not g 10 im sure thats all i could pick up on that 1
Try setting TP to 11800 V 26660 or 11805 H 4580 and move your dish to peak the signal, then blind scan.
i did that it fell off track the bolts are so bad on it im just gonna wait for the new system it got to tease me for 3 min lol il learn my lessions yet i guess
iceburg is their a way to disarm my motor n just do a reg mount and a blind search threw the sky without my system moveing on me again ?
broke off posts to a new thread
I'm confused on what you're asking...what do you mean by system moving?
ok simple i have a motor system when i go outside i set the box to a transponder do a blind look in the sky search for it but then when i come back in after finding it i hit scan it goes back to the original spot so im wondering if i should shut down the motor or can i do that and just try searching for 1 transponder
Sounds like you need to set your set point for the sat that you are on if you don't and you make a change to blind scan it will go back to your old set point. You could set your sat with the motor then go from the box direct to the lnb and just stay on G10.`
If there is a satellite you can easily locate, set your receiver to USALS and tell it to go to that satellite. Then go up on the roof and manually move the motor on the pole until you get that satellite. This works best for your due South satellite.
thanks all i give up a while think im gonna go dunk myself in the atalantic ocean n cool off maybie come back n try again some more later who knwos enjoy the rest of the day
I live a mile from the beach on Lake Michigan. When I was a Freshman at Mich State in 1966, I went swimming on Memorial Day. Not now, by golly. Water temp is 47 degrees. I'd rather plan on a where to put up a 1.2m dish ( if I can come up with one ) .
who ever said jumping into a ocean would cool u off sure is right brrrrrrrrr now to climb back on a nice rooof top n warm up lol
Required Dish Size For KU in New Jersey
Sonicview HD8000 DVB-S2 w/A-1 board
