HD Install Question
PhoneLine
9
Hi Guys,
I have a question regarding an upcoming install. I currently have a Dish 522 dual receiver hooked up via Dish Pro LNB's with a dp34 switch. I am getting 110, 119 and 61.5.
I have a dual tuner HD receiver being installed next week. Does anything on my roof need to be changed, or can the two lines I have feeding the 522 go right into the new HD dual tuner?
Thank you for any info.
If the 722 is replacing the 522, you're equipment configuration is good to go.
True However if you have good line of sight for 129 (and you are within it's footprint) the tech may want to change you out to a 1000.2 Dish so you will not be missing your Regional Sports Networks in HD. These are not carried on 61.5 for most areas.
Lost all SD channels from guide
What features from Tivo would you like added to your E* box?
