I live in the Chicago burbs. The tech says I need to see sat 129 for my HD locals.
I suggested two dishes to the installer. He sighed and said he would go back up on the roof and have another look with that in mind. I thought it was strange that he hadn't already done this. When he came back, he said that the only good spot for any dish is exactly where my current dish is, and since the two dishes can't share the same physical space, two dishes won't work. I'm sure he knows more about installing dish than I do, but I am having a hard time imagining that it's true. We have a large roof, and though the area has many mature trees, we are not in a forest by any means.
He did go ahead and temporarily put the new dish up. He then came inside to check the signal on my receiver. He was getting in the 35 - 40 range on most transponders on 129 and also on either 110 or 119 (can't recall which). He said that was with optimal pointing and that a second dish would not improve it at all. I told him to put the old dish back. After he did, my signal went back up to the 72 - 76 range on most transponders for both 110 and 119. According to the tech, that signal level is just about the max any one can have with a dish 500.
I called dish back to cancel the upgrade. Based on the environmental challenges here, the dish CSR suggested sending out a supervisor to take another look. I said sure, why not.
So, what do you think? Bad karma or bad tech?
What town are you in????
