Woke up to U516. So far only thing new is the addition of Google Asst in settings
Sent from my SM-P550 using the SatelliteGuys app!
I am still on U511 too. Tried out the Upgrade Software tool and no luck. Says I have the latest.It went from 511 to 516? Mine's still on 511
Is your Transceiver Firmware still 0012?Woke up to U516. So far only thing new is the addition of Google Asst in settings
You are correct, no fix for playing off a second Hopper."... Beginning 5/11/18, a new software version will be deployed to all models of Hopper and Wally...."
Based on experience, this is one of the most frightening statements there is.
Please post here what it breaks.
I gather there's still no fix for playing off a second Hopper.
Yes.. it's says 0012Is your Transceiver Firmware still 0012?
Got software version U516 downloaded to both my Hopper 3s. Transceiver Firmware did not change, still 0012. Also, the remote Hopper playback issue is still there. Guess it will be repaired next update.
I guess Dish did not want to release a version 512, after the running gag here about Hopper 3 software versions matching old SD DVR model numbers.It went from 511 to 516? Mine's still on 511
One question is that inter-shore dry transportation facilitation structure located in Brooklyn?I have an inter-shore dry transportation facilitation structure that you may be interested in purchasing.
I see you worked in contracting.Might be.
There's a small fee for the bid package.....
Can you do a speed test thru the Hopper Netflix app?I manually updated both of my Hopper3 receivers to U516. I observed the following:
1) Netflix now reports the correct Internet address on my remote Hopper3 which uses Moca for the internet connection. Prior to this software update, Netflix would report the network address as 169.254.92.182 and all four Netflix servers would show as not connected. This prevented me from viewing 4K content on my one Hopper3 receiver. With the new software up the network displays the correct network address of 192.168.1.21 and all of the Netflix servers connect. The 4K titles now show up and play correctly.
2) Trick play (skip back, rewind, pause, stop) still are broken for the remote Hopper3. I am still anxiously waiting for them to fix this. Scott reports that they are still testing the fix.
3) Accessing programs stored on external drives still requires two attempts.
4) Google assistant is now included. I did not test this.
5) Watching on OTA channel on a Joey2 without first tuning the Hopper3 to an OTA channel still has a lot of pixelation.
6) I did not see any other changes.
Sent from my iPhone using SatelliteGuys mobile app
Thanks for checking the speed. Looks like the Hopper Netflix app speed is still slow. MattG is looking in to the issue. My Hopper 3 is hard wired and sometimes I don't get the 4K content list until I reboot the Hopper. My Hopper 3 speed is 256.239 Mbps, Hopper Netflix app is 19.41, and my LG TV Netflix app is 93.53.The Hopper3 connection speed is 112.978 Mbps. The Netflix connection speed is 18.38 Mbps. Although the Reported Netflix speed is much lower, all of the Netflix servers show as connected and 4K content plays fine.
Prior to this software update, the Hopper3 that was not directly wired to my home network but received the network by Moca would not show 4K content.
My Joey2 still shows the wrong network address in the Netflix app.
