how do i add a second tuner?
briffdogg
5
new york
hi, i had a hr24 running ona single tuner for a while, finally added the second cable, but i cant find the option to change the receivers configuration to dual tuner, when i check the signal strength only one tuner is finding signal, where are the options?
You should just have to re-run the setup and it should see it. Have to ask though, how did you hook up the second cable? Did you have an unused port on the LNB/multiswitch?
Best advice for watching directv on a pc.
whats the next receiver after hr24?
