Hr20-700 Ce 1-4-08
Jimbo
70,689
9,162
NW Ohio - Buckeye Country
Software Download Window:
Friday; January 4, 2008 11PM - 2:30AM ET
Saturday; January 5, 2008 11PM - 2:30AM ET
Probability of CE: 90%
MUST READ AND AGREE TO: - The CE Rules, Faq and Tips Thread... Here
Please join "us" in the CHAT room, about 15 minutes before the window opens... and till... well to the last person turns off the lights...
DBSTalk.Com -
Important notes regarding this version
This has been a very aggressive CE cycle. And with that, there was a sgnificatnly increased level of risk involved with previous versions. While the risk has been greatly minimized at this point, there still is a small risk.
There is LITTLE risk that your box will become a brick... and if you are having too many issues, role back to the national release version.
So please you must absolutely understand these risks, before forcing this download
The Contents of the Release: (Differences based of Last National Release)
  • Items from CE:10:01
  • Items from CE:10:02
  • Items from CE:10:03
  • Items from CE:10:04
  • Items from CE:10:05
  • Items from CE:10:06
  • Items from CE:10:07
  • Items from CE:10:08
Improved
  • 01 - Recording dependability
  • 02 - DoD PgUp/PgDown consistent now
  • 02 - Many MediaShare fixes
  • 03 - Fix for certain video related issues
  • 03 - Audio from video files
  • 03 - VOD resume playback of partially downloaded program
  • 03 - In the DoD Homepage, RED/GREEN will not lock up the STB when viewer is using a custom channel list that doesn't include the DoD channels.
  • 03 - Remote Recording reliability
  • 03 - Remote Recording properly handle cases where recording was already set
  • 03 - 30 sec slip when at end of buffer
  • 03 - Incorrect resolution display
  • 04 - Misc fixes for reported issues
  • 05 - Stability Fixes and Stability after Software Download
  • 05 - Green key cycles audio tracks
  • 05 - Faster signal meter
  • 05 - Fixed frozen video frame
  • 05 - Fixed CC characters from dropping
  • 05 - Fixed review buffer from exceeding 90 minutes
  • 05 - Support play from playlist while getting 771 message on ATSC channel
  • 06 - Misc UI Corrections
  • 06 - UI Menus close when selection is made (like clicking on CC ON)
  • 06 - Green button changes audio directly, and shows banner display
  • 06 - Improved search stability
  • 06 - Interactive app performance improved
  • 07 - Stability improvements
  • 08 - Misc. Under the Hood Updates
Updated
  • 01 - Items in the DoD download queue, will remain after a system reboot
  • [STRIKE]02 - MP3s supported[/STRIKE] 06 - Native MP3 support removed, will return in a later CE
  • 02 - HDTV is a searchable term (=High Def)
  • 03 - Term "VOD" can be used in keyword search
  • 03 - Red Button Delete disabled on Mark and Delete screen
  • 04 - Updates to the UI (more about this after the CE rolls out)
  • 04 - Mediashare ThumbNails improvements
  • 05 - Added Winter welcome screen
  • 05 - Fix resolution indicator in native mode
  • 06 - Reliability when IP address has changed
New feature(s)
  • 01 - Triple Tap Lookup for DoD: When on a DoD page, you can use the # keys on your remote to enter letters in "cellphone/SMS" style. AKA: Hit #2 Three times to get a C
  • 01 - Adult Channel Hiding: This is an update parental control that is currently on the R15. When you enable this, it completely REMOVES the adult rated channels from the listings, almost as if they don't exist.
  • 01 - SLB Updates: Phase I - The live buffer should no longer EVER flush out for any other reason then changing the channel on the live buffer. Note the Phase I, they are planning more updates for the SLB
  • 01 - IP Callback: The ethernet/internet connection, will now be used for communication back to DirecTV for: PPV purchases, GameLounge, and other items that the phone line was required for
  • 01 - Mediashare Video Support: Phase I - You can now access video files from your PC. Note the Phase I, they are still working on additional codec's and full codec support; There is the possibility you will get video but no audio. This is a known issue, and will be worked on for future builds
  • 01 - 30 Second Skip: You will now have the choice between 30s SKIP or SLIP. To enable: Keyword Search 30SKIP or 30SLIP
  • 02 - Boolean Keyword searching, 3 new keywords AALL, AANY, NNOT
  • 02 - 720p/1080i reminder pop up if TV supports but is in 480i/p and tune to HD channel
  • [STRIKE]04 - Hitting Enter on a Full Screen, will display last 6 digits of receiver ID[/STRIKE]
  • 04 - Guide: Channel Color shadding to represent subscribed vs unsubscribed channels
  • 04 - Shortcut for Closed Caption On/Off
  • 05 - Triple-tap 'enter' key moves to next letter
  • 05 - SLB Updates: Phase II - Playback resumes from paused position on tuned channel
  • [STRIKE]05 - Hitting SELECT on a Full Screen, will display receiver ID[/STRIKE]
  • 05 - Hitting DASH on a Full Screen, will display LAST 6 Digits of receiver ID
  • 06 - Edit Series Link options when no episodes are found
  • 06 - SWM Version displayed
Notes
  • Absolutely 100% make sure you understand the risks of this download.
  • [strike]04 - This version still carries a high risk level[/strike]
  • 02 - Boolean keyword search examples: See this post
[/QUOTE]
In the post [post=1369824]HR20-100 {CE:10:03} - 0x1E? Announcement[/post]:
Earl Bonovich said:
Systems in this CE / Version
Probability of CE: 50%
DBSTalk.Com -
Improved
  • 01 - DoD PgUp/PgDown consistent now
  • 01 - Many MediaShare fixes
  • 01 - Fix for certain video related issues
  • 01 - Audio from video files
  • 01 - VOD resume playback of partially downloaded program
  • 01 - In the DoD Homepage, RED/GREEN will not lock up the STB when viewer is using a custom channel list that doesn't include the DoD channels.
  • 01 - Remote Recording reliability
  • 01 - Remote Recording properly handle cases where recording was already set
  • 01 - 30 sec slip when at end of buffer
  • 01 - Incorrect resolution display
  • 01 - Misc fixes for reported issues
  • 01 - Stability Fixes and Stability after Software Download
  • 01 - Green key cycles audio tracks
  • 01 - Faster signal meter
  • 01 - Fixed frozen video frame
  • 01 - Fixed CC characters from dropping
  • 01 - Fixed review buffer from exceeding 90 minutes
  • 01 - Support play from playlist while getting 771 message on ATSC channel
  • 01 - Misc UI Corrections
  • 01 - UI Menus close when selection is made (like clicking on CC ON)
  • 01 - Green button changes audio directly, and shows banner display
  • 01 - Improved search stability
  • 01 - Interactive app performance improved
  • 02 - Stability improvements
  • 03 - Misc. Under the Hood Updates
Updated
  • 01 - HDTV is a searchable term (=High Def)
  • 01 - Term "VOD" can be used in keyword search
  • 01 - Red Button Delete disabled on Mark and Delete screen
  • 01 - Updates to the UI (more about this after the CE rolls out)
  • 01 - Mediashare ThumbNails improvements
  • 01 - Added Winter welcome screen
  • 01 - Fix resolution indicator in native mode
  • 01 - Reliability when IP address has changed
New feature(s)
  • 01 - Boolean Keyword searching, 3 new keywords AALL, AANY, NNOT
  • 01 - 720p/1080i reminder pop up if TV supports but is in 480i/p and tune to HD channel
  • 01 - Guide: Channel Color shadding to represent subscribed vs unsubscribed channels
  • 01 - Shortcut for Closed Caption On/Off
  • 01 - Triple-tap 'enter' key moves to next letter
  • 01 - SLB Updates: Phase II - Playback resumes from paused position on tuned channel
  • 01 - Hitting DASH on a Full Screen, will display LAST 6 Digits of receiver ID
  • 01 - Edit Series Link options when no episodes are found
  • 01 - SWM Version displayed
Notes
  • 01 - Boolean keyword search examples: See this post
Note to other sites and users of those sites:
You are permitted to copy this CE Announcement in it's entirety (including this disclaimer) without modification so long as you provide a clickable link to DBSTalk.com.
In the post [post=1369452]H20-600 {CE:09:04} - 0x4040 Announcement[/post]:
Be sure to monitor the threads and chat room to check on final availability
While you are waiting for the Window to open:
DBSTalk.Com -
  • Items from CE:09:01
  • Items from CE:09:02
  • Items from CE:09:03
  • Items from CE:09:04
Improved
  • General stability improvements
  • SWM Performance improvements
  • Interactive stability improvements
  • Interactive behavior improvements
  • HD PPV stability improvements
  • ATSC stability improvements
  • Interactive to program guide behavior improvement
  • Remote control behavior improvements
  • 03 - Audio Behavior improvements on channel change
  • 03 - Channel Banner UI polish
  • 03 - System message improvements
  • 04 - Digital Audio output stability
Updated
  • 01 - UI polish for Search
  • 01 - UI polish for To-Do list
  • 01 - UI polish for program guide
  • 01 - Minor UI polish for Signal Strength
  • 02 - Remote control behavior improvements
  • 02 - Continued UI polishing
New feature(s)
  • 01 - White GUI
Notes
  • N/A
CE's Cancelled
CE's were cancelled last night for the H-HR20's.
They were trying to add a few other things to the CE and were not able to impliment them early enough.
No word on tonight yet ....
Jimbo
Doesn't appear to be on for Saturday January 5th either.
Nope,
As far as I'm concerned, thats GREAT :)
The last CE I d/l'ed the previous week, is working awesome, EVERYTHING is working great, CID is working 90 % of the time... thats up from 0 % and sometimes 20 % :up
No more audio glitches, no stettering when catching up to live programming or after FF to current recording .
This machine is working the best it has in the entire time I've had a D* HD DVR ... :hatsoff: ot the D* crew !
Jimbo
I didn't look at this thread until it was too late ...
I'm back on the old "stable" build. :( :( :(
Todd,
If that NR worked well for ya, why worry about it ?
If not then I can see some concern.
There will probably be a new CE next weekend, so you can catch right back up :)
Jimbo
HR20-700 {CE:10:07} - 0x1E Announcment
No CE's this weekend
