hr20 upgrade question
blackoutqr
i currently have a 3-lnb dish with 1 line running to an h20. do i need to run another line from the dish and install a 68WB if i replace the h20 with an hr20?
3-LNB dish works fine with the new HR20. You can simply run 2 coax from the 3LNB Dish to the HR20 straight w/o any 68WB.. dual coax for using both tuners in the HR20.
You can always run a single coax too
Without two lines connected, you won't be able to record two shows at the same time or watch one live while recording another one simultaneously.
Hey Gang quick receiver question
HR20 Ratio Setting
