Well, since the olympics are over, and there was no risk of messing up viewing Olympic feeds, I decided to put in the new firmware just released.
First thing I tried was to see if I could stream via HTTP now, but it seemed to be doing the same thing as before, EXCEPT that the window where you type in the URL now has extra characters, allowing you to specify a port number from the remote.
Anyway tried setting up a stream from my desktop, running TSREADER, started TSREADER streaming over port 1234. NOTHING.
I tried all sorts of different settings, but NOTHING seemed to work. Then, I decided to watch the network with a packet sniffer to see what was happening, if anything.
Well, when I started TSREADER streaming, I didn't see anything happen, but then, I moved the Azbox OFF of the IP USER channel, then back onto it, and I could see the Azbox tell the computer that it was there, and listening on port 123 . Yes, 123, NOT 1234, which is what I set it up on.
So, out of curiosity, I told TSREADER to stream on port 123 instead of the usual 1234. BINGO. IT WORKED!!!!
So I don't know if the Azbox was just ignoring the last digit of my port setting, or if it completely ignored the setting, and somehow port 123 is a default port number?
I think I'm going to try putting in a 5 digit port number, like 12345, and see if it communicates on 1234.
After I get the hang of this, I'm going to see how fast of video I can send to the thing.
Anyway, not sure if this is working now because of the new firmware, or if it would have always worked if I had used port 123 instead of 1234.
But this is good news to me anyway, because HTTP streaming was one of the main things I wanted to do with the Azbox.
