I have questions about the Genie system
Dennis Brown
SatelliteGuys Guru
123
I have two satellite feeds coming into my home, which are connected to a SWM at the dish. One feed connects to an HR-24 in the living room and services only that TV. The other feed runs to an entertainment room where it connects to another HR-24. The signal is then split via a Monoprice 4x4 HDMI powered splitter. There are 3 HDMI runs going to the bedroom, kitchen and entertainment room. While most of the hdmi runs are hidden in the walls, one run is exposed. My wife HATES the exposed hdmi run. She saw the Genie ad on TV and wonders if purchasing it will eliminate the hdmi runs, especially the exposed one. Questions:
1. Would I have to purchase (lease) 4 mini genies, one for each TV, including the one in the living room.
2. Would the mini genies eliminate the need for the hdmi runs and the HDMI powered splitter.
3. Would I still be able to watch two different programs at the same time as I can with my two HR-24s. Could I watch more than two different programs at the same time.
4. How are the mini genies wired to the TVs in each room. Can they easily hidden from view.
5. Would it be better to keep the one HR-24 in the living room, which is a "stand-alone" setup, and replace the other one with the Genie system.
Thanks for your help.
Dennis
The Genie is nothing more than a 5 tuner HDDVR. The mini Genies link back to it to use one of the tuners in the main Genie
Yes you would lease all units. A mini Genie is billed $6 a month just like a regular receiver
It would eliminate those runs, but you may have more runs of cable. The mini genie's link back to the main via coax to the SWM splitter
If all you had was the Genie and the HR24 you would still only watch 2 programs. Add mini genie's at other locations would allow you to watch more, so you could have 3 mini's, the genie and an HR24 and watch 5 seperate programs with 7 tuners for recording.
At this point the mini genie is about the size of two packs of playing cards. They connect to the tv via HDMI or a special Din connector if you have none HDMI tv's. Like I said you will have a coax lead back to the SWm splitter for each mini as well. Also you need to be able to point the remote at them to work. They are comming out with RF units so you could hide them from view soon. It's not like the commercial and all cords go away.
Dennis
Thats for you to decide
Complete install ? need to know
Free Printed Channel Guides - DirecTV
