Installation Question
RawisTheGameHhH
SatelliteGuys Guru
135
Southside of Chicago, IL
I have DirecTV coming out this Saturday for installation. I am getting 2 hd dvr receivers and understand that you need 2 lines running to each receiver; currently I only have 1 line running into each room; will the installer run the second line to both rooms during installation? Thanks in advance.
he installer should run the lines from the dish to each receiver. The DRV 's require 2 lines and he is required to install those lines. The installer may or may not require a WB68 Zinwell switch. If you only have 4 lines most likely he will only run the 2 additonal lines. Wall fishing is not included and will be charged.
Make sure that you are satisfied with the installation and satellite signal strenghts on both tuners.
From what you said:
No Multiswitch
4 lines from the dish to each receiver, in groups of two.
2 of the lines can connect to the two existing prewired lines near the ground rod / electric meter area.
Running the other two lines will be where the fun begins.
It is more complicated than that.
Joe
From what you said:
No Multiswitch
Joe
but DTV will run the other 2 lines?
Yes,
The basic install will allow surface runs...outside your house to a place where the tech can drill a wall, enter an attic, basement or crawl space to drill the floor.
The cable can be hidden by vinyl siding but you are looking at four cables from the dish to a ground point and two runs to your two recorders.
The dish may end up on a pole and that will be extra. As will digging in the lines.
Joe
Yes,
Joe
Thanks; we have the spot for the dish all figured out already.
Both the HR20 and HR21 have VOD capability. They must be networked to a router to enable this feature. So far to my knowledge the techs are not yet required to do this as part of the install/upgrade.
As for the 2nd lines, the installer is required to run the additional lines to each reciever. So long as they are NOT ran inside a wall, (ran in the basement/crawlspace and drilled up through the floor; drilled through the outside wall) there is no charge. If you should want them fished inside a wall to a wallplate there is an additional fee to do that, per wall. It varies contractor to contractor. We usually charge $60 for wallfishing.
pole mount will only charge if its a customer request, if thats the only option for line of sight, then its free, and I believe no matter what after 30 ft you have to pay like 3 bucks a foot or something, thats how it was when i was doing installs in oklahoma
HR21-100 Freezing up
Bad 20 box
