Intelsat 5 Hor. &Ver polar.
a_savvin
5
HI,
I installed my dish with viewsat fta receiver.
For some reason I can find/see only channels with Vertical polarization.
Check and make sure your receiver is properly set up for the type of LNB you have. You may not be sending the proper switching voltage to the LNB.
I have Telstar 5 97W
LBN power ON
LNB Type Standard
LNB high 10750
22 hgz off
a_savvin said:
HI,
Is this a newer dish you bought? Just making sure you are not using an old Primestar dish (which most split the Polarity).
a_savvin if you are using a Primestar LNB that could be the reason why you are getting only vertical channels. The Primestar LNB's will also work using a switch.
HI,
Looks like i have to use switch. I just change head connector to another one and I was able to get H polar.
Thanks a lot
i think i have standard single LNBF 10750.
I already installed it, so i couldnt reach head to read label on back side of head.
