Since all HD's eventually will fail I would like to backup the thing up as to not loose all the movies I currently have recorded, but do not see any way of backing it up. Any help appreciated.
Thanks!
Sean
Thanks!
Sean
No. Joey can access an EHD just fine.If you want to view from a Joey, you may need to transfer the recording back to the Hopper.
- When using an external hard drive with a ViP 211, 211k, or DISH 411, the drive should be no smaller than 50 GB and no larger than 1 TB.
- The external hard drive must have its own power supply.
- The external hard drive must not use flash memory and should only be a single-hard disk drive.
What's wrong with flash memory? I don't recall seeing this prohibition before. I also have a bus powered SSD (256GB Crucial) that works fine, and others have reported that 64GB USB thumb drives work quite well too. I have also seen reports here that hardware raid arrays, that present themselves to the host as a single spindle, also work quite well.
As gary implied, an EHD is not a backup since programs you move to it are no longer on the Hopper. You've transferred the problem from one disk to another.
That said, you can back up an EHD with any PC O/S that understands the ext3 file system. Or you could make an identical copy of sectors (which makes the file system irrelevant) to an identical disk. In principle you could do the latter with the internal disk as well, or the former if (as I have read somewhere) your O/S understands the xfs file system.
TheKrell:
We're back to the argument of what works versus what is supported. Zach is doing his job in quoting the company line on requirements...
I was about to post a query on this issue, but will tag on to this. I have an EHD connected to my Hopper, but when I try to call up the EHD icon on the Joey menu, it gives me a message that "This feature is not enabled." So, is there a way to enable it on Joey?
The DVR menu, which I think you are referring to, (as you name it) is only accessible if it recognizes the disk, so your answer is somewhat circular. Yes if it is in the menu it has been recognized or will need formatting.
-Ken
I'm referring to "My Recordings" or the screen you get after pressing the DVR button. I want to know if he sees his EHD in the drop down, red hot key. We have an EHD here and are able to see it from the drop down but we get the "This is not an active feature" message if we select External Hard Drive from the Joey, which I believe is normal but I am double checking on that.
